Hi everybody!
Anyone knows how to modify the font size of the element using any its attribute?
Example:
In my DTD, I've this element:
<!ELEMENT para EMPTY>
<!ATTLIST para
font-size NUMBER #IMPLIED
How to use this attribute 'font-size' to set the font size?
This appear a easy case, but I haven't seen this function in Arbortext.
Hey again Robson,
This would be resolved similar to the example I provided for the field with only an X in it.
The functionality isn't in Editor itself, but in the Styler component.
You would create a new context, with an attribute check on the font-size field.
Of course, each context can only assign one specific font size, so you would need to have a context for each font size you expect users to input. So it might look similar to (replacing 'os' with 'font-size'):
Rafael,
Actually, I need that when I type the attribute on the xml, the font adjusts automatically, like works with the graphics (when I change the attribute of the height, it adjusts the height automatically).
Thanks for all!
I solved this case using the APP.
For this, I saw the interface style and changed the font's height. Like this:
style.height = arguments[0].attributes.font-size+'pt';
