Hello team,
I use .cgm files created in IsoDraw. These graphics contain vector elements and text.
When I publish the file containing these .cgm graphics, they appear in raster format and the text becomes unsearchable.
Are there any settings I need to change to fix this?
Thanks and regards
Pavan
Hello Pavan,
I believe you may have raised this question twice now on the Community.
Are you using the APP or FOSI print Engine?
Have you tested using the steps recommended in a previous community thread regarding this behaviour?
I see you have stated Editor with Styler 7.1 - which maintenance release ? For Example 7.1 M???0
If you are publishing with the APP Print Engine, did you test with changing some of the graphicapptransform setting?
Please Note:
Regards
Alexia
Hello Pavan,
Please Note:
Regards
Alexia
https://www.ptc.com/en/support/article/CS141364?source=search
https://www.ptc.com/en/support/article/CS179196?source=search
Bryon
Hi @PD_11070456,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
