Run ACL code for many documents
aneder
8-Gravel
Hello adepters,
I have document with tag "sdc" - System Difference Code, which content is
"A". I need to change content of all instances of tag "sdc" from A to B.
I wrote simple code which produces such work.
But, I have hundreds or thousands documents with sdc=A. It is not reasonable
to make such work manually. I need to run my ACL code for many documents
from a list of files or for all documents in directory.
Does somebody knows, is it possibly to produce by ACL:
- open document (file name from a list of xml files)
- run ACL
- save and close document
- open next document from the list of files, and so on?
My code for reference for one document:
function sdca2b()
# Replace content of SDC elements from "A" to "B"
# find all SDC and put oids into array
$sdc_array = xpath_nodeset (sdc_nodes,"//sdc");
# Get markups SDC from array
for (i=1; i <= sdc_array.length; i++ )
goto_oid(sdc_nodes[i]);
if (oid_content(sdc_nodes[i]) == "A")
#mark and delete content of tag sdc
mark -noselect -noinvert begin;
goto_oid(sdc_nodes[i], -1);
mark end;
delete_mark;
# insert string "B"
is "B";
Thanks for all in advance,
Alexander Neder
+7 495 737 7878,
Department Manager,
PTS,
16, Marxistskya, Moscow, Russia.
Hi Alexander-
Sure, you can do this. Use the glob() function to get your list of
items, then iterate over it, something like this:
local $files[];
glob("*.xml",$files);
# untested code, debugging is left as an exercise
for ($file in $files) {
local $doc = doc_open($files[$file]);
current_doc($doc);
sdca2b();
doc_save($doc);
doc_close($doc);
HTH
--Clay
aneder
8-Gravel
(To:aneder)
Hello Clay,
Good! It does work!
The only problem was incorrect quotes in glob("*.xml",$files) - probably
mail client repairs them.
Thank you very much!
Final code is:
function all_files()
local $files[];
if (file_directory("C:/work/mydoc") == 1)
{eval "c/work/mydoc is a directory" output=>*}
glob("C:/work/mydoc/*.xml",$files);
current_doc($doc);
sdca2b();
doc_save($doc);
doc_close($doc);
function sdca2b()
mark end;
delete_mark;
is "B";
Sincerely,
Alexander Neder
+7 495 737 7878,
Department Manager,
PTS,
_____
Hi Alexander-
Great, glad it works for you. Now that you've tested it, you can take
out the comment about it being untested code. 🙂
--Clay
