Codebeamer review hub error
MeganB_T
8-Gravel
We are not able to access review hub on our instance of codebeamer and are getting the below error messages:
"Http failure response for http://bocodebeamer:8080/cb/api/configuration/integrationConfig: 429 OK"
Error: Too Many Requests.
Due to this, we can't start any reviews or use the functionality.  Has anyone else encountered this that can support?
Hello @MeganB_T
Please check the article https://www.ptc.com/en/support/article/CS429634. The issue can be solved by disabling apiThrottling
Best regards,
Ivy
Hello @MeganB_T
Best regards,
Ivy
Hello @MeganB_T
It looks like you have a response from a community member. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
Survey Now Live!
Codebeamer Community: we're listening.
Add your voice in our short CSAT survey!
