Hi all,
I was searching in the documentation but couldn´t find it.
I´m trying to have a computed field which takes the ID of the referenced items that are linked through an association with the type "derived from".
Is this possible and if yes, how?
https://support.ptc.com/help/codebeamer/r3.1/en/index.html#page/codebeamer/user_guide/ug_suspectedref_funcs.html
My personal goal is to unify references and associations, so that there are properties you can set on a reference field that cause it to act like today's associations. We do not yet have a planned release for this unification, but that is the approach we are considering.
Hi @MJ_14295943
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Hello @MJ_14295943
Currently, it is possible to do field computations over
however, computation based on associations is not supported.
Best Regards,
Istvan
Thanks for the reply - This was what I feared.
Are there any plans to include this functionality?
