Need for Jama integration into CodeBeamer
Frank_Bernie
7-Bedrock
Major customers of our company ask for integration of their Jama tracking system into our Codebeamer ALM tool.
Does anybody know, whether or not this is possible, and if yes, how a solution would look like?
Any related input is welcome! Many thanks in advance!
Frank.
Kind regards
Frank.
You could use REQIF import/export – I believe Jama now supports REQIF formats. Beyond that I am not aware of any CB-Jama bridge.
Many thanks for your reply! Good hint! I've forwarded this info to our responsible person, who will check together with the customer(s) how to proceed.
Kind regards
Frank.
Kind regards
Frank.
Dear Frank
It all depends on what use case you are trying to accomplish for the integration. We have worked with some of our customer to build the integration. You can connect me on ravi.poojary@tcs,com
Ravi Po
Thank you very much for your answer and your kind offer, Ravi! I've forwarded this to our responsible person, so we can check with the customer(s) what their needs in this matter are. After then, I'll come back to you.
Kind regards
Frank.
Kind regards
Frank.
Jaime_Lee
Community Manager
(To:Frank_Bernie)
Hi,  @Frank_Bernie
It has been over a month since you posted this issue to the community.  Any resolution or hints that you can share with the rest of the community on how you are looking to solve this?  Thank you,  Jaime Lee
Survey Now Live!
Codebeamer Community: we're listening.
Add your voice in our short CSAT survey!
