Automatically suppress multiple features at once with a rule
  • August 13, 2015
  • 3 replies
  • 2842 views
Can I automatically suppress multiple features at one time within Creo? For example, can I define a rule that says to suppress all holes with a diameter of 6mm or less?
    Pretty sure you can do that through Pro/Program (Program). An IF THEN ELSE statement(s) should get you the results you want.
    Explore the search tool.
    For example:
    You can create a search with two rules, the first select all the hole features like shown above:
    the second rule select the ones that have the pretended dimension:
    You can save this query too for later use.
    Explore a little this tool to see how powerful it can be.
    Another option is to create a layer with the previous rules, then you just have click on the layer, "select items" and "supress".
    I found recently that is possible to copy layers from one model to another, this is really handy because you can have a model with all these layers with associative filters and just copy paste it to another.
    Jose
    Jose Costa‌,
    Can you please confirm that "AND" works correctly is this specific case?  In Creo 3 M050 it seems to be ignoring the "AND" and treating the compound query like "OR".
    Yes, the "and" condition is working. The problem is that this filter selects all kind of dimensions, not just diameters.
    Creo 2.0 M110
    José
    Not easily, and not without advance planning.  If this is a model that you have full control over and want to build automation into, then yes.  If you simply want to open anyone's model, locate fasteners by size, and create a rule to suppress, then no.
    • Pro-Program works fine to suppress and resume things, but you have to manually create the logical statements to do so in advance.
    • Rules can be created to find certain types of objects, but to the best of my knowledge Pro-Program cannot make decisions based on them.
    Here are the steps to automate with Pro-Program:
    1. Create a parameter to represent your minimum hole size.  ex. MIN_SIZE
    2. Edit Pro-Program
      1. Add an IF statement before each hole feature based on the parameter and the hole's dimension.
      2. Add an END IF after each ADD/END ADD block.
      3. Save the Program
    3. Control which holes are suppressed by editing the value of MIN_SIZE (and regenerating).
    Example (d18 is the hole diameter):
    IF D18 > MIN_SIZE
        ADD FEATURE (XXX)
       END ADD
    END IF
