Regarding framework in CREO parametric 2.0
ChandraSekhar
How to do frame work in CREO? i mean like modelling a roll cage of an automobile for correct allignment of the rods.. please suggest
2 REPLIES 2
We have customers who have completed roll cages just like your picture using Advanced Framework Extension
You can access AFX Standard using the configuration option afx_enabled to Yes and then re-starting Creo
Videos on how to use AFX are available on Learning Exchange http://learningexchange.ptc.com/tutorials/search?product_id=1&search=framework
thank you for that suggestion
