Save a CREO 3.0 model as a CREO ELEMENT/PRO model
msauthier
8-Gravel
Is it posssible to save a model as CREO ELEMENT/PRO from CREO 2.0 ??
Regards
andy2
7-Bedrock
(To:msauthier)
Files are not backwards compatible for CREO.
You can open earlier versions with later versions, but not the other way around.
5 REPLIES 5
Mathieu,
it is not possible.
Martin Hanak
Martin Hanák
And from CREO 2.0 ??
andy2
7-Bedrock
(To:msauthier)
Using the GCRI tool you can open newer version models from Creo in older versions of CE/Pro or Pro/ENGINEER. This should provide the solution you need:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS34964&posno=1&q=gcri&nav=ptcproductgroups||creo||Product+Group||creo&source=Search
Mathieu
It was discussed in one of the earlier post http://communities.ptc.com/message/254637#254637
This post may give you some more information about this.
