Nov 28, 2014 3:55 PM UTC
Script Error in Creo Parametric 2.0
- 2 replies
- 7449 views
- Translate All
I have been having trouble with my Creo Parametric 2.0. As soon as the application loads up, there is a tab named "script error" popping up and no matter how I try to close it, it keeps recurring, disabling me to use the software. I have tried installing the entire software again and is of no use. I would be really thankful if you could help me rectify the above mentioned issue as soon as possible as the situation is kind of an emergency. I have attached an image capturing the above mentioned problem. Thanking you in advance.
