The value for MASS_GR cannot be changed
tperry
A user is receiving the following error.  "The value for MASS_GR cannot be changed".   The material properties have the correct units and agree with the standards we apply. Any thoughts of what could be the issue? Thanks  CREO2 m120 ~ Windchill 10 m20
Mahesh_Sharma
22-Sapphire I
(To:tperry)
Tim,
Parameter Mass_GR is relation based.
Try updating mass properties using File > Prepare > Change Mass properties > Generate report and try Save and upload.
This is all about Creo, not sure about Windchill as Windchill is out of my expertise.
8 REPLIES 8
MartinHanak
(To:tperry)
what action is user doing ?
MH
Martin Hanák
-        He is checking-out the drawing and part from Windchill.
-        Delete the model from the .prt file
-        Append a step into the same .prt file
-        Assign new material from a library
-        Model check, to assign missing tolerance, and various notes.
-        Save and upload
              o   Failed upload:   “The value for MASS_GR cannot be changed” shows at this point
Note:
-        We have made sure the material properties agree with standard before and after error.    (Millimeter kilogram second)
-        The material library is our standard and has been viewed for proper units, in the event units was recently changed.
-        Even “save and upload” as checked-out, with no changes results in the same upload error.
Hopefully this offers some good information , and I appreciate your help.
Kind regards,
Tim
Mahesh_Sharma
22-Sapphire I
(To:tperry)
Tim,
Is it in all of the files or data specific? Can you upload a sample file to look?
See attached for the .prt file
Mahesh_Sharma
22-Sapphire I
(To:tperry)
Tim,
Nice ... Thank you Mahesh!
Generating the report allowed the file upload without the error.
I appreciate the help.
Tim
SOLVED!!!
Mahesh_Sharma
22-Sapphire I
(To:tperry)
Tim,
I would appreciate if you can mark the appropriate reply to post as correct answer.
Thanks for the suggestion.
I am a first time requester and will follow this process in the future.
Nice forum.
Thanks again for the input.
