Access the UI components after placement them in the navigation pane
ZS_10383889
Hello all, your help is needed again.
I built a new pane using function ProNavigatorpanePHolderAdd(), which adds a layout from resource file as expected.
Q#1: How do I make this pane active immediately, without clicking on the pane tab?
Q#2 Do I need to activate this layout before trying to access UI components?
In order to access UI, e.g. close push button from a new pane I do the following:
- define listener class
class CommitClosePushButtonListener : public uifcDefaultPushButtonListener
public:
    CommitClosePushButtonListener() {}
   ~CommitClosePushButtonListener() {}
   void OnActivate(uifcPushButton_ptr handle);
- activate it
   ProNavigatorpanePHolderComponentnameGet(pane_name, "CommitCloseBTN",       &component_name);
   uifcPushButton_ptr commitClose = uifcPushButtonFind(layout_name, component_name);
   CommitClosePushButtonListener* commitCloseLis = new CommitClosePushButtonListener();
   commitClose->AddActionListener(commitCloseLis);
- define action callback
void CommitClosePushButtonListener::OnActivate(uifcPushButton_ptr handle)
   //debug print
   ProTKFprintf(logfile1, "PushButton\n");
Q#3: Why on testing this button I don't get the debug print?
Many thanks for your answers.
UPD.
I found bug in my code.
should be instead
    uifcPushButton_ptr commitClose = uifcPushButtonFind(current_window_device_name, component_name);
I am left with single question:
If somebody knows?
Thank you.
I do it by async. mapkey. So simply load an async mapkey for the current window the navigator pane is created in.
 Another way would be to find the parent component until you get the tabcontainer and tell it to switch to your tab. But I think that would be much more complex and changes in the std. Dialog from Creo are much more likely to affect your Utility in a way that can cause crashes and that kind of stuff. So the easiest way should be to place a mapkey on the mapkey stack.
Also there are some config options that can cause different behaviors that you need to think of. You can undock the tree from die Creo standard dialog and this affects your navigator pane, too.
Br,
Eike
Eike, thanks a lot. I will look at the mapkey solution. Is it part from OTK?
I would use ProMacroLoad() but there is also one in otk with RunMacro()
Br,
Eike
It seems that mapkey is an ugly workaround solution. Is that what is done as the tree pane is loaded as the first tab? Can't believe it.
