I've been using VB API for a couple of weeks now and now i want to add a button to the ribbon. But I can't even start an application in CREO.
My code looks like this:
Imports pfcls
Module Module1
Public asynconn As New CCpfcAsyncConnection
Public conn As IpfcAsyncConnection
Public session As IpfcBaseSession
Sub Main()
user_initialize()
user_terminate()
End Sub
Sub user_initialize()
conn = asynconn.Connect("", "", ".", 1)
session = conn.Session
End Sub
Sub user_terminate()
conn.Disconnect(5)
End Sub
End Module
My protk.dat file:
NAME test
EXEC_FILE D:\Users\Creo_7\Test_Button.dll
TEXT_DIR D:\Users\Creo_7
STARTUP dll
delay_start FALSE
allow_stop TRUE
REVISION 2001
END
config.pro:
protkdat D:\Users\Creo_7\protk.dat
What is a minimum requirements for creo VB application to run inside of CREO and how than can I add button on the ribbon?
Errors that I'm getting
Take a look here:
VladimirN, thank you for those materials bu the didn't help me.
Is there anything like this for VB API. I've found it in user guide for TOOLKIT.
I'm able to start and use scripts that I have for now by running them in visual studio but I can't register application in creo.
Some solutions for this error:
All those articles are for TOOLKIT but I'm using VB API.
