Assistance Needed with Automating Dimension Report in Creo TOOLKIT
Haydena
Dear Sirs,
I hope this message finds you well.
I am reaching out regarding the Creo drawing inspection function shown in the attached image. This function automatically generates a dimension report and allows for the export of dimension data to an Excel file via the "Export to XLS" button.
I am looking to automate this process using Creo TOOLKIT, specifically to automatically extract dimensions and generate the report. However, I am not very experienced with programming.
I would greatly appreciate any guidance, tips, or code examples on how to achieve this. Thank you in advance for your assistance!
Best regards,
Lan Haydena
Hi @Haydena
Thank you for your question!
Best regards,
Catalina
PTC Community Moderator
PTC
RPN
(To:Haydena)
There is not a lot of feedback here. For what it worth, to give you a clue how this could work!
# export only a dimension value from type diameter
# add tolernce values and inspection basic info
# sample out (of course out is without the '#')
# Symbol,Value,TolL,TolH,Inspection,Basic
# d2,32.000,0.005334,0.005334,No,No
# d12,5.334,0.005334,0.005334,No,No
# d27,10.667,0.005334,0.005334,No,No
proc SimpleByType {model {sep {,}}} {
	set B(0) No
	set B(1) Yes
	set dims [ps_dim list -model $model]
	set out [file join [ps_pwd] dim-info-by-type--$model.csv]
	set fp [open $out w]
	puts $fp "Symbol,Value,TolL,TolH,Inspection,Basic"
	foreach item $dims {
		# assign id sym val to a var from the list item
		foreach {id sym val} $item break
		# get the dim Object handle
		set dimObj [ps_dim from_ids $id]
		if {[string equal [$dimObj cget -type ] DIAMETER ] } {
			# get the tolerance
			set tol 	[$dimObj  cget -tolerance ]
			# assign lower, upper value
			set toll 	[lindex $tol 0 ]
			set tolu 	[lindex $tol 1 ]
			#export if inspection or basic
			set insp 	[$dimObj  cget -inspection ]
			set basic 	[$dimObj  cget -basic ]
			set data [join [list $sym [format %.3f $val] $toll $tolu $B($insp) $B($basic)] $sep]
			puts $fp $data
	# close the file
	close $fp
Just plain Tcl
YaroslavSin
(To:RPN)
Just plain Tcl
Good... But ho to use this example?
RPN
(To:YaroslavSin)
Hmm, check the Tcl Wiki, write a Mail, get the env, be surprised 😉
