Automatically DXF exported
Palari
3-Newcomer
I have this problem: a cad model, a panel developed in sheet metal, with an opening in the center (a rectangular cut) with A and B dimensions. The model is parametric and is updated with a whole series of relations inserted. Obviously, this model is linked to a DRW for the creation of the DXF file for processing on the machines.
It is possible and how, from a listing from excel file or notepad file with the various dimensions of A and B, to launch a mapkey or a bach file that automatically makes the DXFs of the various panels "n" times as many as there are variants in the listing?
Pala
MartinHanak
(To:Palari)
simple OOTB solution does not exist.
You can generate trail file and play it.
How to get sample trail file:
  • start Creo
  • open part
  • modify A, B
  • regenerate
  • open drawing
  • export DXF
  • close drawing
  • close part
  • erase all
  • exit session
Now you can open trail file in Notepad and look for A value, B value, DXF filename.
To get batch trail file:
  • remove the end of sample trail file
    • begin with !Command ProCmdOSExit was pushed from the software. line
  • put first two lines from sample trail file into batch trail file
  • repeat other lines from sample trail file (place individual values into every copy)
  • when finished start Creo and play batch trail file
Martin Hanák
MartinHanak
(To:Palari)
  • start Creo
  • open part
  • modify A, B
  • regenerate
  • open drawing
  • export DXF
  • close drawing
  • close part
  • erase all
  • exit session
Martin Hanák
