Automation - Export part/assembly to different STEP file options
SikSha_4499023
3-Newcomer
Hi all, Greetings!
I need to automate export part/asm to STEP format with different options OR through different profile files in Creo. I checked Mapkey does not work. Anybody suggests how to do it? OR any API or batch files that can solve/work.
Try to change config.pro option "export_profiles_step" (pointing to .dep_step) and do export.
If this will be working for you than you can write two mapkeys: each for a profile.
In mapkey:
1. change option (path and file .dep_step)
2. export to step
Hi @SikSha_4499023,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina
PTC Community Moderator
