Automation of PDF Generation process in Creo
vadiraj
Need suggestion on automating PDF generation process in PDM (Creo tool).
Normally PDF file will be generated once CAD file check-in with required modifications. Idea here is to automate PDF generation process once part is check-in. so that one more manual step for generating PDF can be avoided in Creo.
Kindly suggest on
I think it is possible to achieve on Windchill side using Creo View Adapters
Yes, Windchill can generate pdf while generating the representation after checkin automatically.
vadiraj
(To:YaroslavSin)
Thank you 🙂
quick question - could you help to provide steps on this tool regarding functionality.
How this can be integrated with windchill or Creo
Thank you
BenLoosli
(To:vadiraj)
You need to have CreoView publishing enabled and set up so Windchill can automatically publish your files upon check-in. We also republish them when submitted as part of a promotion request.
