Need suggestion on automating PDF generation process in PDM (Creo tool).
Normally PDF file will be generated once CAD file check-in with required modifications. Idea here is to automate PDF generation process once part is check-in. so that one more manual step for generating PDF can be avoided in Creo.
Kindly suggest on
I think it is possible to achieve on Windchill side using Creo View Adapters
Thank you 🙂
quick question - could you help to provide steps on this tool regarding functionality.
How this can be integrated with windchill or Creo
Thank you
You need to have CreoView publishing enabled and set up so Windchill can automatically publish your files upon check-in. We also republish them when submitted as part of a promotion request.
