Dear PTC users,
maybe you have an idea how to solve my problem. I am going to develop a synchronous J-Link application in Creo Parametric (but version does not play a role in this case). I just want to compile my project, check if it works, i case of ocurring malfuctions recompile it, checking again, recompiling and so on. but i always have to restart Creo because the new compiled classes are not recognized while running Creo. I also tried to stop and/or unregister my plugin in aux application and restart/reregister it. i also tried to rename my plugin in creotk.dat.
Does anyone know a technique to avoid this?
In last time i always developed asynchronous apps. there you dont have this problem beacuse you can connect and disconnect to/from session each time.
works perfectly fine with netbeans. thanks for your quick response. i also found your presentation. You called it "How to Debug ProENGINEER Applications in Any Language" from PTC World Event 2010
Hi Mark,
Can you shared presentation for how to debug JLink with Eclipse IDE.
Maybe this thread can help you:
https://community.ptc.com/t5/Customization/J-Link-debugging/td-p/80699
If you have maintenance:
https://www.ptc.com/en/support/article?n=CS65288
Hi HamsterNL,
I am facing issue for Connection Refuse of VM.
Here I attached snap of configuration setting of Cronfig.Pro,Protk.Dat ,Remote VM and Error Snap.
Please help and needfull.
