Create a New Component Parameter in Assembly that is editable by occurrence
bwudtke
Hi Community,
We are looking to create a new component parameter in assembly mode that is editable by occurrence.  A similar attribute that has the same capabilities is  ECAD_OWNER.  We were able to create the attribute in Windchill under the EPM Document Uses Link, and it performs correctly in Windchill, but we want to have this edittable in Creo.  I am wondering if anyone knows how to add a component parameter in Creo like this.  Here is a picture example of what the functionality would represent.  It would not check out the components within the assembly as it is considered a assembly parameter.
Windchill 11.0
Creo 4.0 MO90
RPN
(To:bwudtke)
I don't understand your request in total but ...
you have already setup the Windchill Preference "Attributes to be published on Occurrence" in "EPM Service Preferences" -> "Build Service Preferences" I guess. This is the name of the Parameter.
You have a Link Type where Attributes is propagated from the WTPart to the EPM.
In Creo I'm not sure if the Parameter is Created automatically, if "not" it is a feature parameter and the feature is a component in your assembly.
Create the Parameter via Toolkit via
ProParameterWithUnitsCreate()
where the ProModelitem()
TYPE is PRO_FEAT_COMPONENT and the
ID is the Feature ID and the
OWNER for sure is the Root Assembly,
No component path, because this does not make sense.
Hope that helps ...
jpiotrowski
(To:bwudtke)
We have Component Parameter Management automation that can help create and store component parameters that can be used across your organization. These parameters can be grouped and labeled for specific assembly use cases. Attributes such as designated and locked can be added as well, so you don't need to do it manually. Users can then export your assembly structure and add/edit the component parameters in Excel, then import them back into Creo.
Please see a demo video (here) on this Component Parameter Management functionality and let me know if there are any questions.
Cheers,
John Piotrowski, Co-Founder & Product Manager
CadActive Technologies - www.cadactive.com
