We are currently experiencing a service disruption impacting community and support login. Our teams are working to resolve the issue.
I want to verify the family table in the existing part file using VB.NET. Because of some values are updated even if i use regenerate process table not verified.
Please help me if you anyone know the process / idea.
Balaji.S
Thank you ketan...![]()
Hi ketan
I have one doubt in family table process.
Just i want to add one more cell,value and suppress in family table using coding.
Which is easy method for that process.
Thnaks
Balaji,S
plz try method append of class IpfcFamilyTableColumns
Hi Ketan,
Thanks for your reply.
I will check with that method and let you know the status.
Thnks,
Balaji.S
Hi Ketan,
Now I am suppressing the particular hole feature in the part file without adding cell in family table.
I tried with below coding and it show error ( Object reference not set to an instance of an object)
Dim f1 As IpfcFeature
Dim sup As IpfcSuppressOperation
Dim op As New CpfcFeatureOperations
Dim solid As IpfcSolid
Dim LmodDoc As IpfcModel = retrieveModelFromStdDir(session, EpfcModelType.EpfcMDL_PART, parttwofile)
If Not LmodDoc Is Nothing Then
LmodDoc.Display()
session.CurrentWindow.Activate()
new_parameter = LmodDoc
model = session.CurrentModel
solid = Ctype(model,IpfcSolid)
f1 = solid.GetFeatureByName("Hole 1")
'f1 = solid.GetFeatureById(67)
sup = f1.CreateSuppressOp() ------------------------------------here i am getting error (Object reference not set to an instance of an object)---------------------
op.Append(sup)
solid.ExecuteFeatureOps(op, Nullable)
End if
Thnks
Balaji.S
seems you are not getting feature object into variable f1 by API GetFeatureByName. Check return status of this API.
I faced issue with API GetFeatureByName earlier. I checked and faced same again that even though Hole 1 is present, API does not give object of same by API GetFeatureByName.
I tried something as below and worked for me:
Dim objFeature As IpfcFeature
Dim objSupOp As IpfcSuppressOperation
Dim objFeatures As IpfcFeatures = objSolid.ListFeaturesByType(True, EpfcFeatureType.EpfcFEATTYPE_HOLE)
For intCnt As Integer = 0 To objFeatures.Count - 1
objFeature = objFeatures.Item(intCnt)
objSupOp = objFeature.CreateSuppressOp()
Next
Only limitation is that all holes into a part will be considered for supress operation by above code. Benefit is that you don't have to worry about what is Feature ID of hole feature to pass it into API GetFeatureByID.
Hi Ketan,
Sorry for the delay in replying to your mail.
I went meeting just now I seen your mail, I am trying with specific id based and I will try with your method of coding also.
I will let you know the status shortly.
Thnks
Balaji.S
Hi Ketan,
Yes, You said correct for getting feature object into variable error.
I tried your method and my old one also, both options are working.
Thanks lot for your support
Please check below method coding correct…
Dim rsup As IpfcResumeOperation
Method-1
solid = session.CurrentModel
Dim objf As IpfcFeature
Dim objs As IpfcSuppressOperation
Dim objff As IpfcFeatures
objff = solid.ListFeaturesByType(True, EpfcFeatureType.EpfcFEATTYPE_HOLE)
For inc As Integer = 0 To objff.Count - 1
MsgBox(objff.Item(inc).FeatTypeName.ToString())
objf = objff.Item(inc)
objs = objf.CreateSuppressOp()
op.Append(objs)
solid.ExecuteFeatureOps(op, Nothing)
Next
Method-2
If f1.Status.ToString() = "0" Then
op.Append(sup)
ElseIf f1.Status.ToString() = "5" Then
rsup = f1.CreateResumeOp()
op.Append(rsup)
End If
Thnks
Balaji.S
Hi Ketan,
Above method coding is correct?
Thnks
Balaji.S
Method 2 is best to use when you now ID of feature and is not going to change through out application scope.
Hi Ketan,
Thank you for your reply, i will update in my coding part.
Thnks
Balaji.S
Hi Ketan,
How are you, how is going...
Currently I am connecting creo 2.0 using the below method-3 only.
But, now i try with connect method (1,2), if i try that method it shows error (pfcExceptions::XToolkitNotFound)
Dim asyncConnection As IpfcAsyncConnection
Dim cAC As CCpfcAsyncConnection
Dim session As IpfcBaseSession
Dim objccpfcconnection As New CCpfcAsyncConnection
Dim exePath, workDir
exePath = "C:\Program Files\PTC\Creo 2.0\Parametric\bin\parametric.exe"
workDir = "C:\Program Files\PTC\Creo 2.0\Common Files\F000\vbapi\vbapi_examples\models"
Try
'Method-1
_objIpfcConnection = objccpfcconnection.Connect(Nothing, Nothing, Nothing, Nothing) - pfcExceptions::XToolkitNotFound
session = asyncConnection.Session
session.LoadConfigFile("C:\Users\Public\Documents\config.pro")
'Method-2
'_objIpfcConnection = objccpfcconnection.Connect(DBNull.Value, DBNull.Value, DBNull.Value, DBNull.Value)-pfcExceptions::XToolkitNotFound
'session = asyncConnection.Session
'session.LoadConfigFile("C:\Users\Public\Documents\config.pro")
'Method-3
'cAC = New CCpfcAsyncConnection
'asyncConnection = cAC.Start(exePath + " -g:no_graphics-i:rpc_input", workDir)
Catch ex As Exception
MsgBox(ex.Message)
Finally
End Try
I configured creo 2.0 parametric as per guide instructions only.
Please tell me where i done mistake.
Balaji.S
better to start new discussion thread for this.
Ok
Sorry Ketan,
I know its years later, but for anyone else wondering why this won't work refer to this:
Pro/ENGINEER Wildfire 5.0 introduces the No-Resolve mode, wherein if a model and feature regeneration fails,
failed features and children of failed features are created and regeneration of other features continues. However,
VB API does not support regeneration in this mode. The method pfcSolid.Solid.Regenerate throws an
exception IpfcXToolkitBadContext, if Creo Parametric is running in the No-Resolve mode. To continue with the
Pro/ENGINEER Wildfire 4.0 behavior in the Resolve mode, set the configuration option regen_failure_handling
to resolve_mode in the Creo Parametric session.
