Creo AFx v. 11.0.4
NE_12819279
2-Explorer
Creo AFx v. 11.0.4
Creo AFX parameter and relation modifications
I am working on trying to put in custom parameters and relations within the AFX parts. I figured out how to add parameters that are user defined by modifying the AFX  config start_mdl.cfg file, but the relations are not working. I need relation - driven parameters for multiple parameters when any beam profile for AFX is opened so I want them applied globally.
I cannot find the afx_start_model that the start_mdl.cfg in AFX seems to reference for the current relations, and I have tried adding .rel files to reference relations within the start folder and also have tried editing the param_relations folder within the beam profiles without any luck.  I am not sure if it is a file location or syntax error, or if there is something I am missing.
I essentially need to populate the AFX start parts for every beam profile with my own parameters and relations.
Any advice or information would be greatly appreciated.
Hi @NE_12819279
Thank you for your post.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina
PTC Community Moderator
PTC
in folder parts\profiles  create param_relations.txt file and put some relations inside.
That should do the work.
Restart Creo after that and try to create some profiles.
SikiF
