In PTC article CS363748 are for the various Creo main versions TOOLKIT sample projects attached.
However, only the Debug configuration is preconfigured for these.
As our company is currently working with Creo 10.0, I have taken a closer look at the example project for this version.
However, my statements also apply to the projects of the other versions.
The Debug configuration can be compiled and linked, but in my opinion it is not correctly preset:
The project setting "Configuration Properties > C/C++ > Runtime Libary" should be changed from "Multi-threaded DLL (/MD)" to "Multi-threaded Debug DLL (/MDd)", shouldn't it?
Even if this change is made, the project can still be successfully compiled and linked.
However, if you then add the line "#include <string>" to the other header files at the beginning of the program code, the DLL can no longer be created and the following error messages appear in the output console:
Rebuild started...
1>------ Rebuild All started: Project: Creo_x64_tktemplate, Configuration: Debug x64 ------
1>PTTestBug.cpp
1>protk_dllmd_NU.lib(srcutf.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcutf.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(srccore.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(srccore.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcwrappers.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcwrappers.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcmemmgr_common.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcmemmgr_common.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcmemmgr.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcmemmgr.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(srci18n.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(srci18n.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(threadlibsrc.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(threadlibsrc.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcutfstr.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcutfstr.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcmemmgr_mt.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcmemmgr_mt.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(ctstack_utils.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(ctstack_utils.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcunicode.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcunicode.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcnet.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcnet.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcsconv.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcsconv.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcmtbase.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcmtbase.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(ctwithclang.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(ctwithclang.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcbase.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcbase.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcmemmgr_slim.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcmemmgr_slim.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcps.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcps.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(baselibsrc.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(baselibsrc.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(srccoll.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(srccoll.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(bufsrc.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(bufsrc.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(stringsrc.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(stringsrc.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(osapisrc.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(osapisrc.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(streamsrc.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(streamsrc.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcstream.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcstream.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcproc.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcproc.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcstdstream.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcstdstream.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(ostoolssrc.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(ostoolssrc.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(membufsrc.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(membufsrc.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcstring.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcstring.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(srctime.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(srctime.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcenv.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(srcenv.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(nmscomm.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(nmscomm.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(nmsclnt.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(nmsclnt.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1>protk_dllmd_NU.lib(stackwalksrc.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in PTTestBug.obj
1>protk_dllmd_NU.lib(stackwalksrc.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match value 'MDd_DynamicDebug' in PTTestBug.obj
1> Creating library …\Creo10_x64_tkSynctemplate_DLL\x64\Debug\\pt_bug.lib and object …\Creo10_x64_tkSynctemplate_DLL\x64\Debug\\pt_bug.exp
1>msvcprtd.lib(locale0_implib.obj) : error LNK2019: unresolved external symbol __imp__free_dbg referenced in function "public: static void __cdecl std::_Fac_node::operator delete(void *)" (??3_Fac_node@std@@SAXPEAX@Z)
1>msvcprtd.lib(locale0_implib.obj) : error LNK2019: unresolved external symbol __imp__malloc_dbg referenced in function "public: static void * __cdecl std::_Fac_node::operator new(unsigned __int64)" (??2_Fac_node@std@@SAPEAX_K@Z)
1>…\Creo10_x64_tkSynctemplate_DLL\x64\Debug\\pt_bug.dll : fatal error LNK1120: 2 unresolved externals
1>Done building project "Creo_x64_tktemplate.vcxproj" -- FAILED.
========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
If I reset the project setting for the "Runtime Libary" to the value "Multi-threaded DLL (/MD)", strangely enough, it works again with the creation of the DLL.
Do you know what else I am doing wrong if I use the setting "Multi-threaded Debug DLL (/MDd)"?
Domenic
In case toolkit project, I think, no need to change flag to /MD.
For Release DLLs need to use "Standard libraries" /MT and remove flags for debugging (see below).
From Creo 9 toolkit documentation:
Why would you want to change the configuration if you don't have problems compiling and debugging?
My aim is to create a Release configuration in addition to the Debug configuration.
In the Release configuration, I would then select the value "Multi-threaded DLL (/MD)" as the "Runtime Libary".
And in the setting "Configuration Properties > Linker > Input", the release library protk_dll_NU.lib should be used instead of the debug library protk_dllmd_NU.lib.
This gives me a Debug configuration that can be used during development and a Release configuration for the publication of an official version.
Release DLLs are normally somewhat smaller and also a little more performant.
Today I read through the PTC article CS237146, where the six toolkit lib files are explained.
I noticed that I was misled by the "md" in the name of the protk_dllmd_NU.lib library: This "md" obviously doesn't mean that it is the debug version of the protk_dll_NU.lib library.
So I think this issue is over for now.
Thanks for your support!
Hi @DomenicLaritz I think I have also been misled into thinking protk_dllmd_NU.lib is the debug version.
What did you need to do to resolve this issue for you? Which .lib do you need to include in the Debug configuration? And are you able to use /MDd for this?
Ben
Hi Ben,
I use the runtime library setting "Multi-threaded DLL (/MD)" and the library protk_dllmd_NU.lib for both debug and release configuration.
I tried a lot, but I wasn't able to create a Toolkit DLL with the runtime library setting "Multi-threaded Debug DLL (/MDd)".
According to PTC article CS182582 compiling with /MDd should work, if you use the preprocessor macro _ALLOW_ITERATOR_DEBUG_LEVEL_MISMATCH.
I haven't tried this out by myself.
Thanks for the suggestion, I tried this out, but it did not work. Further investigations found that _ALLOW_ITERATOR_DEBUG_LEVEL_MISMATCH can resolve
error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2'but not
Ah, ok - too bad.
Thanks for trying it out.
We have found similar to you, and for our projects we need to use Multi-threaded DLL (/MD) for the Debug configuration to avoid LNK2038 build issues.
An issue that is awkward that we have to manage to keep on top of the build issues, but we have never found an ideal resolution or an explanation, so I am interested in hearing other peoples views on this.
