Somehow I lost the section C-C cutting plane. How do I get it back?
How do I not show the (2) blue lines which I believe are used to construct Section C-C cutting plane.
In the message log, is it telling you anything, like possibly, section c-c aborted?
Try to do a Resume all features. The Cross section may have been suppressed accidentally.
Where do I find Resume all features?
I managed to get the section view back but I cannot get rid of the blue line "Sketch_2". I do not know what this line is. When I look at each feature to see where Sketch_2 is, they all just say Section 1. Any idea how to hide this blue line or at least find out what it is related too?
If you go to the model and delete sketch_2, does it try to delete other features? If so, it is used as a reference to those features.
Could that sketch feature be used in a higher level assembly maybe? You would then not want to delete them.
You can add them to a layer in the model (they may already be on a layer) and hide that layer in the drawing if you can't delete the feature.
In the model, you can also use the reference viewer on the tools tab to investigate references. It's not too hard to learn but it's a powerful tool to that will prove useful in the future.
Winner !! Great job Stephen. It must have been hidden so the sketch_2 wasn't showing. I went into Tree Filter and checked Feature, Annotations and Suppressed Items. One of those turned the sketch back to visible in the tree. I hid that sketch and like magic the blue line is gone. Thank you VERY much.
