Generating a model with Java OTK_model tree
VladiSlav
Hello!
I created a part window using the code:
      Model tryModel = curSession.CreatePart ("Testing1");
      tryModel.Display ();
Here's what happened:
Then to create the tree elements I need to access the model in the current session:
Session session = pfcSession.GetCurrentSession ();
Model currModel = session.GetCurrentModel();
MessageDialogOptions msgOpts = pfcUI.MessageDialogOptions_Create();
MessageButtons buttons = MessageButtons.create();
buttons.append(MessageButton.MESSAGE_BUTTON_OK);
msgOpts.SetButtons(buttons);
msgOpts.SetMessageDialogType(MessageDialogType.MESSAGE_WARNING);
msgOpts.SetDialogLabel("OTK Sweep Feature Create ERROR");
if(currModel == null)
              session.UIShowMessageDialog("Model must be in current Session",msgOpts);
              throw new Exception("Method: pfcSession::GetCurrentModel \nMsg: otkSweepCreate");
The condition is not met and a warning appears:
How to create a model in a tree?
Has anyone built models using OTK Java?
Help me please.
Best Regards!
I found a mistake.
Everything works now.
My code is:
public Extrude()
public void OnCommand() throws jxthrowable
		createPart();
	else
		modelBuild();
public void createPart() throws jxthrowable {
    	try
	Session curSession = pfcSession.GetCurrentSessionWithCompatibility(CreoCompatibility.C4Compatible);
	String modelLocation = "......";
	String model_name = ".......";
	ModelDescriptor desc = null;
	curSession.GetCurrentWindow().Activate();
	desc = pfcModel.ModelDescriptor_CreateFromFileName(model_name);
	desc.SetPath (modelLocation);
	Model template = curSession.RetrieveModelWithOpts(desc, pfcSession.RetrieveModelOptions_Create());
	Model newPart = template.CopyAndRetrieve("Test", null);
	Window newWindow = curSession.CreateModelWindow(newPart);
	newPart.Display();
	curSession.SetCurrentWindow(newWindow);
	newWindow.Activate();
	template.Erase();
	} catch (Exception e)
	System.out.println("1: " + e);
	Session session = pfcSession.GetCurrentSessionWithCompatibility(CreoCompatibility.C4Compatible);
	Model currModel = session.GetModel("......", ModelType.MDL_PART);
	currModel.Erase();
public void modelBuild()  throws jxthrowable {
	try {
	int quan;
	String name;
	String allname = "";
	WSession ses = (WSession)session;
	Model model = ses.GetCurrentModel();
	Solid solid = (Solid)model;
	ModelItems items = solid.ListItems(ModelItemType.ITEM_FEATURE);
		for (int j = 0; j < items.getarraysize(); j++) {
			name = ((Feature)items.get(j)).GetName();
			quan = ((Feature)items.get(j)).ListSubItems(ModelItemType.ITEM_SURFACE).getarraysize();
			allname = allname + name + ": " + quan + "\n";
	//session.UIShowMessageDialog(allname, null);
	Surface plane = (Surface)((Feature)items.get(3)).ListSubItems(ModelItemType.ITEM_SURFACE).get(0);
	Surface plane1 = (Surface)((Feature)items.get(2)).ListSubItems(ModelItemType.ITEM_SURFACE).get(0);
	Selection dirSels1 =  pfcSelect.CreateModelItemSelection(plane, null);
	Selection dirSels2 =  pfcSelect.CreateModelItemSelection(plane1, null);
	Elements elements = Elements.create();
	//PRO_E_FEATURE_TREE
	Element elem_0_0 = wfcElementTree.Element_Create(wfcElemIds.PRO_E_FEATURE_TREE,null,0);
	elements.append(elem_0_0);
	//PRO_E_STD_FEATURE_NAME
	Element elem_1_0 = wfcElementTree.Element_Create(wfcElemIds.PRO_E_STD_FEATURE_NAME, pfcArgument.CreateStringArgValue("My_extrude"),1);
	elements.append(elem_1_0);
	//PRO_E_FEATURE_FORM
	Element elem_1_2 = wfcElementTree.Element_Create(wfcElemIds.PRO_E_FEATURE_FORM, pfcArgument.CreateIntArgValue(1),1);
	elements.append(elem_1_2);
	//PRO_E_FEAT_FORM_IS_THIN
	Element elem_1_3 = wfcElementTree.Element_Create(wfcElemIds.PRO_E_FEAT_FORM_IS_THIN, pfcArgument.CreateIntArgValue(0),1);
	elements.append(elem_1_3);
	//PRO_E_EXT_SURF_CUT_SOLID_TYPE
	Element elem_1_4 = wfcElementTree.Element_Create(wfcElemIds.PRO_E_EXT_SURF_CUT_SOLID_TYPE, pfcArgument.CreateIntArgValue(917),1);
	elements.append(elem_1_4);
	//PRO_E_REMOVE_MATERIAL
	Element elem_1_5 = wfcElementTree.Element_Create(wfcElemIds.PRO_E_REMOVE_MATERIAL, pfcArgument.CreateIntArgValue(-1),1);
	elements.append(elem_1_5);
	//PRO_E_STD_EXT_DEPTH
	Element elem_1_6 = wfcElementTree.Element_Create(wfcElemIds.PRO_E_STD_EXT_DEPTH, null,1);
	elements.append(elem_1_6);
	//PRO_E_EXT_DEPTH_FROM
	Element elem_2_0 = wfcElementTree.Element_Create(wfcElemIds.PRO_E_EXT_DEPTH_FROM, null,2);
	elements.append(elem_2_0);
	//PRO_E_EXT_DEPTH_FROM_TYPE
	Element elem_3_0 = wfcElementTree.Element_Create(wfcElemIds.PRO_E_EXT_DEPTH_FROM_TYPE, pfcArgument.CreateIntArgValue(128),3);
	elements.append(elem_3_0);
	//PRO_E_EXT_DEPTH_FROM_VALUE
	Element elem_3_1 = wfcElementTree.Element_Create(wfcElemIds.PRO_E_EXT_DEPTH_FROM_VALUE, pfcArgument.CreateDoubleArgValue(100),3);
	elements.append(elem_3_1);
	//PRO_E_EXT_DEPTH_TO
	Element elem_2_1 = wfcElementTree.Element_Create(wfcElemIds.PRO_E_EXT_DEPTH_TO, null,2);
	elements.append(elem_2_1);
	//PRO_E_EXT_DEPTH_TO_TYPE
	Element elem_3_2 = wfcElementTree.Element_Create(wfcElemIds.PRO_E_EXT_DEPTH_TO_TYPE, pfcArgument.CreateIntArgValue(268435456),3);
	elements.append(elem_3_2);
	//PRO_E_STD_SECTION
	Element elem_1_7 = wfcElementTree.Element_Create(wfcElemIds.PRO_E_STD_SECTION, null,1);
	elements.append(elem_1_7);
	//PRO_E_STD_SEC_SETUP_PLANE
	Element elem_2_2 = wfcElementTree.Element_Create(wfcElemIds.PRO_E_STD_SEC_SETUP_PLANE, null,2);
	elements.append(elem_2_2);
	//PRO_E_STD_SEC_PLANE
	Element elem_3_3 = wfcElementTree.Element_Create(wfcElemIds.PRO_E_STD_SEC_PLANE, pfcArgument.CreateSelectionArgValue(dirSels1),3);
	elements.append(elem_3_3);
	//PRO_E_STD_SEC_PLANE_VIEW_DIR
	Element elem_3_4 = wfcElementTree.Element_Create(wfcElemIds.PRO_E_STD_SEC_PLANE_VIEW_DIR, pfcArgument.CreateIntArgValue(1),3);
	elements.append(elem_3_4);
	//PRO_E_STD_SEC_PLANE_ORIENT_DIR
	Element elem_3_5 = wfcElementTree.Element_Create(wfcElemIds.PRO_E_STD_SEC_PLANE_ORIENT_DIR, pfcArgument.CreateIntArgValue(1),3);
	elements.append(elem_3_5);
	//PRO_E_STD_SEC_PLANE_ORIENT_REF
	Element elem_3_6 = wfcElementTree.Element_Create(wfcElemIds.PRO_E_STD_SEC_PLANE_ORIENT_REF, pfcArgument.CreateSelectionArgValue(dirSels2),3);
	elements.append(elem_3_6);
	WSession wSession = (WSession)session;
	ElementTree	elemTree = wSession.CreateElementTree(elements);
	FeatCreateOptions featOpts = FeatCreateOptions.create();
	featOpts.append(FeatCreateOption.FEAT_CR_INCOMPLETE_FEAT);
	WRegenInstructions regenInstr = wfcSolidInstructions.WRegenInstructions_Create();
	WSolid currSolid = (WSolid)currModel;
	WFeature extrudeFeat = currSolid.WCreateFeature(elemTree,featOpts,regenInstr);
	elemTree = extrudeFeat.GetElementTree(null,FeatureElemTreeExtractOptions.FEAT_EXTRACT_NO_OPTS);
	Element sketchElem = GetSketcherElement(elemTree);
	SpecialValue sketchSpvalue = sketchElem.GetSpecialValueElem();
	Section sketch = sketchSpvalue.GetSectionValue();
	sketch.SetIntentManagerMode(true);
	Point2D center = wfcSession.CreatePoint2D(0.00,0.00);
	SectionEntityCircle circle = wfcSection.SectionEntityCircle_Create(center,300.00);
	SectionEntity entity = (SectionEntity)circle;
	sketch.AddEntity(entity);
	circle = wfcSection.SectionEntityCircle_Create(center,20.00);
	sketch.SetIntentManagerMode(false);
	sketchSpvalue.SetSectionValue(sketch);
	sketchElem.SetSpecialValueElem(sketchSpvalue);
	featOpts.insert(0, FeatCreateOption.FEAT_CR_NO_OPTS);
	extrudeFeat.RedefineFeature(null,elemTree,featOpts,regenInstr);
	catch (Exception e)
	curSession.UIShowMessageDialog("Error!", null);
static Element GetSketcherElement(ElementTree elemTree)
	try
	ElemPathItems sketchItems =  ElemPathItems.create();
	ElemPathItem sketchItem0 =  wfcElementTree.ElemPathItem_Create(ElemPathItemType.ELEM_PATH_ITEM_TYPE_ID,wfcElemIds.PRO_E_STD_SECTION);
	sketchItems.append(sketchItem0);
	ElemPathItem sketchItem1 =  wfcElementTree.ElemPathItem_Create(ElemPathItemType.ELEM_PATH_ITEM_TYPE_ID,wfcElemIds.PRO_E_SKETCHER);
	sketchItems.append(sketchItem1);
	ElementPath sketchPath = wfcElementTree.ElementPath_Create(sketchItems);
	Element element = elemTree.GetElement(sketchPath);
	return(element);
	catch (Exception e)
	return null;
Thanks everyone!
I hope it will be useful!
17 REPLIES 17
Hello!
I have advanced a bit. Instead of creating a model from scratch, I copied the template and then deleted the template from the session:
template.Erase();
After that, two problems arise:
1) (First problem) I run the example "otkCreateSweep.java" immediately after creation, but the code throws the same error "Model must be in current Session". But if I first create a model with one code and run an example with the second, then everything works. I understand that the model appears in the session only after the execution of the code ends, so it is impossible to do everything right away.
So I had to do this:
static int i = 1;
public Create_Part()
@Override
	if (i == 1)
		{createPart();
		i++;}
	else
		addCreateSweep();
But it does not look like a good solution.
2) (Second problem) I am now dealing with how to make a simple extrusion in the created model. I found the code in the PTC knowledge base that allows you to unload the tree of model in XML, it seemed to me that this would be useful, but the code could not be launched.
Knowledge Base Code:
try {
         Log.write("===============================================");
         Log.write("===  OnAfterFeatureCreate was called   =======");
                                 wSolid = (WSolid)(session.GetCurrentModel());
         if ((currModel.GetType() == ModelType.MDL_ASSEMBLY) || (currModel.GetType() == ModelType.MDL_PART)) {
            try {
               //wSolid = (WSolid) sld;
               //cast exception com.ptc.wfc.Implementation.pfcPart$Part cannot be cast to com.ptc.wfc.wfcSolid.WSolid
               wSolid = (WSolid) currModel;
               wfeat = (WFeature) feat;
            } catch (Throwable e) {
               Log.write(" cast exceptoon : " + e);
            ModelItem item = (ModelItem) feat;
            if (item.GetType() == ModelItemType.ITEM_FEATURE) {
               Log.write("GetType =  ITEM_FEATURE");
               Log.write("featName=" + feat.GetName());
               if (wfeat != null) {
                  ElementTree elementtree = wfeat.GetElementTree(null,
                        if (elementtree != null) {
                        Log.write("elementtree is not null print to XML file");
                        elementtree .WriteElementTreeToFile(ElementTreeFormat.ELEMTREE_XML, "feat.xml");
               } else
                 { Log.write("wfeat is null");}
         } else
            Log.write("current model is not part or assem");
         System.out.println("Exception caught finial : " + e);
         e.printStackTrace();
         Log.write("Exception caught in Body : " + e);
Therefore, now I understand the documentation for Creo® Parametric TOOLKIT, it says about the element tree, but everything looks pretty confusing.
I will be grateful if someone will help me with these problems, if you have experience.
Thanks in advance.
Best Regards!
Hello!
Try to pass new model as argument to addCreateSweep (Model currModel)
addCreateSweep(newPart);
And comment/delete a line Model currModel = session.GetCurrentModel(); in addCreateSweep ()
Thanks!
True, now the model does not produce errors, but the code still does not run 😞
Yes, I did so.
Here is my code:
		    newPart.Display();
		    template.Erase();
	public void addCreateSweep(Model currModel)
	try
		try
If your program don't rise any exceptions, than try to use debugger and go thru code step by step to find a line where is a problem and to understand what happened.
Thanks!
I would like to unload the model tree in xml, and there already see the whole structure.
To do this, I need this code:
try {
            try {
               } else
         } else
It requires "feat" and "wfeat", which is not clear where to come from.
I tried, as in the example "otkCreateSweep.java":
WFeature sweepFeat = currSolid.WCreateFeature (elemTree, featOpts, regenInstr);
But here a tree element is created, and I need to count, so I think there should be a different logic.
Do you know anything about this?
Best Regards!
Is Feature or ModelItem (extrusion, revolve, sweep, CSYS and so on). Is a feature for which you want to export his element tree to xml file.
You can get this feature by interactive selection or build it by your self using id and type of the feature.
Thanks, all worked well!
I shortened the code in from an example:
		try {
	         SelectionOptions dirSelopts = pfcSelect.SelectionOptions_Create("feature, datum, csys");
	         dirSelopts.SetMaxNumSels(new Integer(1));
	         Selections dirSels = session.Select(dirSelopts, null);
	         ModelItem item = dirSels.get(0).GetSelItem();
	         Feature feat = (Feature)item;
	         WFeature wfeat = (WFeature) feat;
	         ElementTree elementtree = wfeat.GetElementTree(null, FeatureElemTreeExtractOptions.FEAT_EXTRACT_NO_OPTS);
             elementtree.WriteElementTreeToFile(ElementTreeFormat.ELEMTREE_XML, "feat.xml");
	         System.out.println("????: " + e);
But now I have another question.
I create a plane using FET. I make a plane with an offset from the example:Снимок.PNG
The PRO_E_DTMPLN_CONSTR_REF parameter was created as follows:
//PRO_E_DTMPLN_CONSTR_REF
Element elem_3_1 = wfcElementTree.Element_Create(wfcElemIds.PRO_E_DTMPLN_CONSTR_REF,pfcArgument.CreateSelectionArgValue(dirSels.get(0)),3);
That is, I select the reference plane interactively. But I need to set the reference plane existing in the model from the code.
Do you know how to refer to the plane existing in the model?
Thanks in advance!
Best Regards!
you must to create a Selection with ModelItem (plane) by your self.
Take a look "Programmatic Selection"
Thanks for the advice!
I wrote this code:
ModelItems items = solid.ListItems(ModelItemType.ITEM_SURFACE);
Surface plane = (Surface)items.get(0);
Element elem_3_1 = wfcElementTree.Element_Create(wfcElemIds.PRO_E_DTMPLN_CONSTR_REF,pfcArgument.CreateSelectionArgValue(dirSels1),3);
It works. But only with those planes that are associated with a solid, as written in the manual:
Interface ModelItemOwner/ListItems/Parameters (Note that only those surfaces associated with solid geometry are included in the list of model items when you specify ITEM_SURFACE or null as the Type . Surfaces of Creo Parametric Surface features and Quilts are not included).
But I need to get access to any surfaces, and not just those that are associated with solids.
Do you know how to fix it?
Excuse me for asking so many questions, I started working with the API not so long ago.
Thanks in advance.
Best Regards!
I not sure but, I think, if you interesting to get surfaces from separate surface (feature created as surface), than need to firs get item of this feature.
Then take a look at chapter "Geometry Evaluation"
ps: "To obtain a list of the quilt features with their component datum surfaces, specify ITEM_QUILT."
Thanks, that helped a lot!
Now I'm dealing with extrusion.
I start, the element is created, but broken, it does not have a section.
Checking the code, I found on which line it throws an error.
My code is:
public class Extrude extends DefaultUICommandActionListener {
	static int i = 0;
	public Extrude()
		++i;
		if (i == 1)
			createPart();
		else if (i>1)
			DTM();
	public void createPart() {
    	try
			String modelLocation = ".........";
			String model_name = "........";
		    newPart.Display();
		    template.Erase();
	public void DTM()  throws jxthrowable {
		try {
			int quan;
			String name;
			SelectionOptions dirSelopts = pfcSelect.SelectionOptions_Create("datum,surface,curve,csys,edge,axis");
		    //PRO_E_FEATURE_TYPE
		    Element elem_1_1 = wfcElementTree.Element_Create(wfcElemIds.PRO_E_FEATURE_TYPE, pfcArgument.CreateIntArgValue(0),1);
		    elements.append(elem_1_1);
		    //PRO_E_STD_SECTION
		    Section sketch = sketchSpvalue.GetSectionValue();         //!!!!Error is here!!!!
		    SectionEntityCircle circle = wfcSection.SectionEntityCircle_Create(center,40.00);
		catch (Exception e)
	  Get PRO_E_SKECTHER element using wfcElementPath_ptr
	  NOTE: To get an element with level greater than 1 you must
	  define element path with respect to PRO_E_FEATURE_TREE
	try
		return(element);
	catch (Exception e)
	return null;
I created an xml file for the failed element. I attach it.
You do not know what is wrong?
Thanks in advance!
Regards!
Create feature using element tree it is not easy task. My advice is manually create Extrusion feature in Creo. Than export this feature to XML and compare it with yours XML. Maybe you miss something.
Another way is edit exported XML to meet your task and import it for creating new feature.
And do you really want to create a whole model using element tree? I think this is extremely hard. Maybe you can use "template" model. Then just change desired dimensions. Or use UDF (user defined feature).
PS: several examples of extrusion feature in C toolkit  ...\Common Files\protoolkit\protk_appls\pt_userguide\ptu_featcreat
Thanks!
I have already created XML for extraction obtained in Creo. From the comparison, I concluded that my PRO_E_SKETCHER is not filled, as the error shows, as well as the created element in the model tree (there is no section there).
Now I just deal with the tree of elements, looking for possible options.
I do not want to create a model from the template, because the logic and various options make the model heavy. In my opinion, the generation will allow transferring all calculations to the program code, which will facilitate the model.
I did not know about UDF functions, thanks.
I saw examples from protoolkit, on them I also tried to make the code.
Best Regards!
I found a mistake.
My code is:
public Extrude()
		createPart();
	else
		modelBuild();
    	try
	newPart.Display();
	template.Erase();
	currModel.Erase();
	try {
	int quan;
	String name;
	//PRO_E_STD_SECTION
	catch (Exception e)
	try
	return(element);
	catch (Exception e)
	return null;
Thanks everyone!
