How I can continue to use weblink tool which is relied on IE browser ActiveX?
WhiteChen
8-Gravel
I am using Creo Parametric - Release 4.0 (connected) Release 4.0 and DatecodeM150
I have a weblink tool which is relied on IE browser and ActiveX, but the IE browser will not be supported in future, how can I continue to use my tool, any alternative method?
please ask PTC Support.
Martin Hanák
You can use Chromium with weblink. Check documentation.
And ...\Common Files\weblink\weblinkexamples\jscript\pfcUtils.js
sjuraj
(To:WhiteChen)
Aa ysinitsyn said, you can use chromium and also you can use newer js api creojs instead of weblink (starting with creo 4)
