can anybody give me some advice about model tree ?
Do I understand correctly, that you want to insert additional customized lines into the model tree?
This should not be possible, as the tree reflects the model structure. Of course by adding features/items you will add lines as well.
Or are you aiming at adding columns?
Gunter
Gunter
Yes, you understand correctly, I want to insert additional customized lines, thanks for answer.
