Hello everyone, I'm new to Creo and I am trying to figure out how to add objects to a Model.
I tried to create a new Part file and add some 3D points (as an example) but I cannot see them in a Window. Also, the number of ModelItems didn't change.
Could you tell me, please, how to add new ModelItems?
If I understand the documentation, this will just init a 3D point struct, nothing more. You need to create a feature, or place an UDF to create new model items. Expect 2 lines more, of code 😀
RPN thank you for the answer.
Actually, it was not just 2 lines of code ( I needed to create a feature tree), but I managed to do it! 🙂
