I am creating some features using Object toolkit application C++.
But once operations are done, I cant undo them.
Is there anyway with which I can add undo point till the state before I started by application
Hello Martin,
Thank you for your reply.
Your suggestion seems great, but it may not fit my requirement.
As there are multiple operations are done on part, I just want to remove last operation that was done on my part. Just last.
I see a way around with using your suggestion, but Can you please help me with Object Toolkit code/function for the erasing and reopening model.
@RS_9601780 wrote:
Hello Martin,
I am sorry i can't help you I am not software developer.
Hi Martin,
Thank you for your kind reply. I will search for the probable solution and update if I find one.
Thanks again
