I have a number of relations based udfs for creating manifold block designs. All the logic is built using Relations in Creo-Parametric. There is a specific logic I have built around transferring dimensions in decimal form (say 3 decimal places) to a 3D hole-note written with relations, so that the hole note shows the 3 decimal places. (Usually, when transferring to string form, Relations only transfers the integer part of the dimension) I have a work around for this, which works well, but then, every such hole, has to have the logic built in its relations.
Is it possible to have this common logic as a subroutine, written in the part relations , which I can access, every time I want to increase the decimal places ? I can call this subroutine with the value, number of places I want to show so that the sub-routines returns a string value with the correct decimal places.
This is the relations program for a counter bore dia with 2 decimal spaces and a counter bore depth with 3 decimal spaces.:
x=itos (CBORE_DIAMETER*10^2)
l=string_length(x)
if(extract(x,(l-1),2)=="00")
y=extract(x,1,(l-2))
else
if(extract(x,l,1)=="0")
y=extract(x,1,(l-2))+"."+extract(x,(l+1-2),1)
else
y=extract(x,1,(l-2))+"."+extract(x,(l+1-2),2)
endif
endif
c="."
if (acc<1)
c=""
endif
a=itos(CBORE_DEPTH*10^acc)
l=string_length(a)
b=extract(a,1,(l-acc))+c+extract(a,(l+1-acc),acc)
/*" ?" is the symbol for dia. in the 3D note
HN1="S.Face"+" ?"+y+" - "+b
Please note that "HN1" is what is called in the 3D Note
This works pretty well for each hole individually. But one can notice that this bit of program would be more efficient, if used as a sub routine.
Dear RPN
Thanx for your comments. My purpose is to convert the given dimension as decimal in the Hole notes (which are in string form), so that, when I call the HN or HN1 in the hole table when doing the 2D of the drawing, they come in their proper decimal form. Say for a hole of M5 thread, the pre-hole drill dia is 4.5(mm). If I call the drill dia in the hole note directly, it will be displayed as 5mm which is wrong info. It should be called in as 4.5mm. This little snippet does this beautifully, but if I have to write that bit of code every time for every parameter, it becomes a little clumsy. It would have been served better if it could be called as a sub-routine. Hence this post
Dear BenLoosli
Thanx for the info that it is possible to convert decimal values directly to decimal values in string form (Hole Notes) in Creo-11. I am at the moment using Creo - 10.5. I will try this shortly and come back
Dear KenFarley
Thanx for your comment that it is not possible to have sub-routines in Relations at the moment. But I still look forward to the time when it will be possible to do so. It would make a lot of my work easier, perhaps for other functions. (if I shift to Creo-11, perhaps it would be easier for this function!!)
Saju
Thanx all
What version of Creo are you using?
With Creo 11, there is now a rtos function that eliminates the trickery of converting a real number to a string for use in notes.
There is no capability of defining subroutines or any looping logic in relations. Relations are an analogue of reading a tape; all commands are executed once, line by line from top to bottom.
First and as long I remember, the number of decimals can be driven by special format specifier in Creo, check the Doc and I guess for 3D drawings this should work.
second, you may know this already, but just in case.
If you need 2 decimals from 14.35673
multipy this by 10^2 (the power of this 2 decimals = 100 😉)
the result is now 1435.673, to round add 0.5
Now you have 1436.173
Convert to an integer would give 1436
At least divide back by 10^2 and you get
14.36 (If you Substract the int of this you will get 0.36, just in case).
This works for any number of positive decimals and even 0! and Negativs to cut🙃
All can be written in one statement
like (with dot for dash, No idea for the English words, for this German statement 😅😅😅)
RealValRes = int(RealVal*10^NOD+05)/10.0^NOD
NOD = Number of Decimals
In the relation menu try Eval of the right hand expression, to see the outcome.
Just use the correct function in Creo and replace int = floor as far I remember.
For this there is no string conversion required.
Dear RPN
Dear BenLoosli
Dear KenFarley
Saju
Thanx all
I would not hold out any hope for subroutines being implemented in relations. That would require a complete change to the processing method for the code. In particular, adding the capability of looping structures adds the possibility of infinite loops being written through careless coding or unanticipated variable states. Having Creo freeze up because you didn't realize a certain condition could arise would be nasty.
Dear KenFarley
I agree that it could be nasty if we inadvertently put in an infinite loop. But this is true even for normal program bugs. At the very least, one would have to do a Control Alt Del sequence and stop the entire program. Looking at the positive side, it would reduce coding to a larger extent and make it neater. It is like having Auto lisp in Autocad. Programs developed by individual users have made the systems so much more acceptable to the general user, and more satisfying and automatic to boot. A long time back (before I completely switched to Pro/e 2001... about 2003), I was working 3D manifold block designs in Autodesk Mechanical Desktop, doing almost all the things I do in Creo using my own code in Auto-lisp and V-lisp. Its true that Creo has enhanced over that, but still, I have tasted the programming enhancing my job speeds, which put me upto developing a whole lot of UDF's, helping me to progressively and successfully make very compact, complicated hydraulic manifold blocks automatically.
Saju
