I am using Creo Parametric - Release 4.0 (connected) Release 4.0 and DatecodeM150
请问如何使用TOOLKIT给尺寸文本添加“文本符号”?
How to add "text symbol" to dimension text using TOOLKIT?
Translated with google translate by Iuliana Nuta, 16. june 2022
Hi your application needs to perform the following:
that's to say Select an existing dimension then browse Dimension tab > and pick a symbol in the palette.
Once your application gets the dimension, here is the function to call to set a Symbol: ProDimensionSymbolSet()
The page points to the shipped example: TestDimension.c:
