How to assign model name to default CSYS
MartinHanak
This discussion is my reaction to CSYS name should alway be the Part Name idea.
Attached CSYS_rename_CR3_prvek4.zip file contains following files:
How to install script:
  1. create C:\PTC directory
  2. save zip file into C:\PTC directory
  3. unzip zip file into C:\PTC directory to get structure show on picture
  4. open config.pro file and copy two lines into your config.pro
How to run script:
  1. launch Creo 3.0 (in my case it is M100, English version)
  2. open part
  3. run mapkey dd1
  4. open assembly
  5. run mapkey dd2
Notes:
  • .au3 ... source file
  • .exe ... compiled source file
  • if you unzip zip file into directory different from C:\PTC, then you have to modify path defined in config.pro
  • notes in source file are written in Czech language, I hope that translate.google.com transfers Czech texts into English properly
Good luck !
Martin Hanak
Martin Hanák
17 REPLIES 17
Hi Martin!,
Thank you for this tool with source code. This gives a whole new level to Creo Mapkeys combined with external application. And it's pretty clever how you did the renaming.
I didn't know, something like this is possible! I cannot say my thanks with words!
I wanted to ask, if you could share the $F2-mapkey you are using for this renaming method of CSYS. I have original scripts from IPM with $F2 for opening model tree, so the .exe files don't work for me.
Thanks again and I wish you the best!
MartinHanak
(To:mliska)
I don not understand well your last paragraph:
My guess ... you want call mapkey by clicking F2 key instead of clicking dd1 key combination. If this is the case then simply change config.pro line using Notepad.
mapkey dd1 @SYSTEMstart C:\\PTC\\CSYS_rename_CR3_prvek4\\rename_csys_prt.exe;
to
mapkey $F2 @SYSTEMstart C:\\PTC\\CSYS_rename_CR3_prvek4\\rename_csys_prt.exe;
MH
Martin Hanák
I think he was looking at the .au3 source code which calls the F2 key
This method will rename the csys to match the part number only or will it automatically match the csys name when I create a new part?
the mapkey renames coordinate system (feature no.4) in model tree.
MH
Martin Hanák
Short video showing dd1 and dd2​ results.
Martin Hanák
Not useful solution
Not useful solution
RPN
(To:MartinHanak)
In Tcl I need one Line of code for this:
ps_feat set_name [lindex [ps_visit type csys] 0] [file root [ps_model cur]]
Next a procedure, which is more save:
Here a movie ...
dschenken
(To:RPN)
Not a usable solution.
RPN
(To:dschenken)
You are almost right, but p-Shell is running in a SandBox, you need to copy one folder only.
The "PNG" shows the env, the movie shows what happen if you add a new folder to your SandBox programs.
  1. Start the Csys app,
  2. keep it running,
  3. do the source code edit
  4. Source the edited file again
  5. Run the newly created button
This is not a final app, but should show how easy it is to make an update or test new code.
Note: This Tcl program run in synchronous mode.
Cheers
dschenken
(To:RPN)
Does p-Shell ship from PTC?
RPN
(To:dschenken)
Ha, as I guess you work for PTC, and this is not from PTC Smiley Very Happy
dschenken
(To:RPN)
If I worked for PTC then I would have a PTC badge.
Feel free to link to the source.
RPN
(To:dschenken)
Use the mail address from the Wiki to get more information.
RPN
(To:dschenken)
100 Kudos for this statement Smiley Very Happy
ToolkitExpert
2-Explorer
(To:RPN)
functionality can be customized by toolkit for open/rename/saveas/import
