How to create construction lines in a section?
dstaves
Hi all,
I am trying to create construction lines in a section that is to be displayed in a sketch in my Creo model. Looking at the API, there appears only methods for setting the endpoints of the line using a pfcOutline_ptr object. Is there another class that these sectionEntities inherit from that determines their display styles?
Thanks in advance,
Dan
sully7
(To:dstaves)
Is the sketch in a 2D drawing? or 3D model?
I'm not sure about in OTK, but in the original toolkit, I think you can do this via ProDtlentitydataConstructionSet for a 2D drawing. For a 3D sketch/section, you may have to go into the feature element tree... but I'm not quite sure.
President & Founder
CadActive Technologies - www.cadactive.com
dstaves
(To:sully7)
Thank you for your response James!
It seems that the function required to determine the construction status of a section curve is not yet implemented in OTK. I was able to use pro/toolkit to implement your suggestion.
Thanks again,
Dan
