I realized that there a 'Debug' utility under the 'Option' menu in ProE5.0 on some machines, but not mine.
Dose anyone know how to enable this, I want to use its UISpy or dialog test command.
I'm a Pro toolkit developer, so I think that would be a big help in my work.
P.S.
The UISpy is sort of like the Spy++ come with Visual studio, that you can use to inspect your ProE UI dialog's properties.
