How to do "carve-out modeling" or "sub-modeling" with beams?
Hi everyone.
We to solve a problem with large frame-type models. The idea is to claculate a whole frame using idealized beams first, obtain resultant forces in certain parts and apply equivalent forces on solid models afterwards. How to do it?
I started from testing the functionality of Creo Simulate 2.
Firstly, I created a test frame, where beams were created using sketched curves and datum curves.
Creo Simulate model:
Results window - stress Von Mises:
I am interested in obtaining forces in the central C - frame, which is most loaded. When I go for Beam Resultant - Force - Y and choose the frame, I obtain some results, which I am not able to interpret.
While applied vertical force along Z direction is 7500 N, fringe image shows two opposite resultant forces.
The resultant forces along X axis look bizzare as well:
What does that all mean? I just want to find out where can I obtain correct resultant forces and on what areas should I apply them?
Thanks a lot in advance, the
Mikhail
