I am working in Creo 2.0 M080. In my application I am opening Creo assembly file , using ProToolkit API I would like to know if assembly has any component with unresolved/failed constraint. Unresolved constrain for component could be due to external/internal reference are not available.Such part does generate a Regenerate failures.
So is there any API using which I can determine if given component has unresolved/failed constrain. I did tried API's which give states as packaged , under constrained , placed , unplaced but it didn't helped to get the correct results.
Milind
