How to get display name of dimension using protoolkit?
Ben_C
I would like to know what protoolkit function is needed to obtain the name of the dimension as it appears in the tree, "TEST_DIM_TAG" in this case.
Calls to ProModelitemNameGet & ProDimensionSymbolGet both return "d0"
Thank you in advance.
Ben_C
(To:RPN)
The correct API calling sequence needed is:
ProAnnotationElementGet(p_handle, &element)
ProModelitemNameGet(element, dimTag)
Thanks for the help
8 REPLIES 8
RPN
(To:Ben_C)
Is this a sketched dim, or how was this created?
Ben_C
(To:RPN)
I don't believe it is a sketched dimension, but I'm not sure how it was created as this file was passed to me.
File has been attached.
YaroslavSin
(To:Ben_C)
Demensions was shown. This is an annotation items.
RPN
(To:Ben_C)
It's an annotation  Element
Yaroslav was faster, and you may need Toolkit for 3D Drawings.
Ben_C
(To:RPN)
Okay thank you. Do you know which Protoolkit API call can be made to obtain the displayed name (TEST_DIM_TAG) in the model tree?
EDIT: I have solved this. The API calling sequence needed is:
Thank you for the assistance.
RPN
(To:Ben_C)
No for this 3D Drawings API I'm out. But did you checked ProDimensionTextEstring*()
But I never used this.
Ben_C
(To:RPN)
Thanks for the help
RPN
(To:Ben_C)
Congrat, you fixed it by yourself!
