Do you need Open external file or Run some program while you working with Creo Parametric? You can use custom key sequence.
Creo Customization: How to open external file with Mapkey (youtube.com)
Cool, thanks
You are welcome ![]()
I tried this tip to open my Chrome web browser and it works, but it does not become the main window. On the monitor, it opens behind Creo.
Can I make it open in front of Creo?
Hi Kevin
I tried it with Chrome web browser - it is work perfect. Chrome was main opened window
(my OS - Windows 7 64bit)
Vladimir
I see the problem. I ran the mapkey with Chrome already open and so what happened is that a second instance of Chrome opened and did not become the main window.
If I close all Chrome windows it works as you described.
I wish the command prompt window with the black background did not stay open. Any ideas?
Kevin
Try this to have the command prompt window close.
This example opens Google Chrome.
@echo off
C:\Users\kbradberry\AppData\Local\Google\Chrome\Application\
start chrome.exe
exit
Hi Kevin
For your mapkey you can set and combine any of batch command (open / save / set custom variables / rename etc.) - your new mapkey Will be perfect and usefull.
In my example I want to show how you can open external file.
Thanks for comment ![]()
Vladimir
Very cool. Thanks Vladimir. I now have a mapkey using OS script to open Microsoft Calculator.
@echo off
REM
set %windir%\system32\
start calc.exe
exit
Nice work Kevin and Thanks for sharing.
For All:
Do you need some help with Batch File Command? Click here:
Index of the Windows CMD command line or Some examples
Vladimir
