Hi..
I have a pipe assembly created in pro-piping, now i want to read its bend location from ProToolkit, so please can i know its API or any other way to read it.
From front end i can get it from Piping -> piping info -> bend location -> select pipe segment -> select csys.
Thanks.
Prashant Pandarkar
Hi Prashant,
I have not ever programmed this activity but here are 2 possibilities off the top of my head. BTW, I am using the WF 5.0 Pro/TOOLKIT API.
Hope It Helps,
Patrick Williams
I just went through this while trying to convert an application from Pro/DEVELOP to Creo Parametric 2.0 Toolkit which used a pipe feature.
prodb_get_pipe_feat_refs has no equivalent in Toolkit. The pipe feature element tree is not exposed. The pipe feature is obsolete in CP3.
