Hi All,
I am developing an user interface for protoolkit application by using the creo UI editor. As the creo ui editor is structured in a grid form, I could not set a back ground image in the created application UI. The background image is required to add some labels on it.
Kindly suggest some ideas.
Thank you!
Hello!
I think, you can use Drawing Area component. But only in programming way (not in UI Editor) you can place background image and labels on it. For example, like Shape tab in Hole feature.
Hello!
Tell me, please, how to set a picture on the background of DrawingArea?
I managed to do it for Label.
But there the picture is simply inserted with the size that it has, but I would like to control the size of the picture.
Regards!
