How to show system dialog Select Parameter?
YaroslavSin
Hello!
Anyone have ideas how to show system dialog Select Parameters from toolkit application?
This dialog is using for selecting parameters for family table and in Inheritance feature.GUIGUI
I don't want to recreate this functional by my self using GUI Editor.
sully7
(To:YaroslavSin)
In Pro/TOOLKIT, the method is "ProParameterSelect".
In ObjectToolkit, you can run "SelectParam" or "SelectParams" on a pfcModel object, or pfcModelItem object.
FYI also - if you'd like to then apply the parameters to a FamilyTable, you can use "ProParameterToFamtableItem" to apply it into the family table operations.
Let me know if you'd like more info -  I can put together some example code for you if you'd like.
James Sullivan
President & Founder
CadActive Technologies - www.cadactive.com
sully7
(To:YaroslavSin)
James Sullivan
President & Founder
