Installing the "PE In Depth Tutorials", the "
HenryJanssen
Hello, I cannot (fully) use the ten "In Depth Tutorials" I have downloaded and installed. The index of the tutorial is visable in the left pane of the reader but the content isn't shown in the right pane of the reader. I am using Vista 32. I learned that the "ten tutorials" are compiled HTML files (.chm). Do I need a special kind of reader? Furthermore. It would be nice if the "ten tutorials" could be accessible from the CC-PE help menu, just as "Quickstart Projects". What must I do to get going? Thank you in advance for your response. Kind regards, Henry Janssen
Hello, the pages can also be accessed thru the Help Button in the upper access list. Help - Quickstart Projects. In the next window you may use the "Index" button to get a list. Or you move to the next project. The only item I'm aware of is that Windows is restrictive to show chm files if they have been installed on a remote server or network share. Tests recommended are to use the local installed Modeling PE Help (see above) or to install the download files in a local directory without restrictions. For reference: One can download the Quickstart Models as well as the tutorials from our web page at (Being registered) http://www.ptc.com/products/cocreate/modeling-personal-edition/
