J-Link. Set the name for drawing note
Yaroslav
7-Bedrock
Hello!
ModelItem.SetName return exception XToolkitBadInputs.
DetailNoteItem note = (DetailNoteItem) drawing.CreateDetailItem(instrs);ModelItem itm = (ModelItem) note;
itm.SetName("note_test");
Any ideas?
I would be grateful for any help!
Hello, Mark!
Thank you for help!
Unfortunatly, it is a bug in API. ProModelitemNameSet() API returns PRO_TK_BAD_INPUTS (-2) while setting name to a detail note.
Hi -
I can't say for sure what caused your error, but you should find it easier to isolate the problem if you did not cast the original object to different types.
Try this instead:
     DetailItem item = drawing.CreateDetailItem( instrs ) ;
     item.SetName( "note_test" ) ;
DetailItem is a subclass of ModelItem, so a DetailItem object can execute any method that a ModelItem can.
Also, are you certain that ModelItem.SetName is throwing the exception and not Drawing.CreateDetailItem ?
|+|  M a r k  |+|
Hello, Mark!
Thank you for help!
