I would like to confirm that this is possible.
I have a pattern of datum points (defined as offsets from a spherical coordinate system). The pattern is in a table.
Is it possible using J-Link to edit this pattern table? Change coordinates as well as add pattern members with new values?
FYI, I will be reading these values from a text file located on our network...
Has anyone done this or similar and would you be willing to share your code?
