I am currently using Creo elements/pro 5.0, I want to know which java version has to be used for Jlink application.
Gopichand RB
Gopichand RB
my suggestion:
Hi Martin
In one of your previous answer you suggested the following link for java version to be used for compiling the java files, shall I use the java 1.4.1 SDK and JRE for compile the java file.
Gopichand RB
@Gopichand wrote:
Hi Martin
Gopichand RB
mentioned PDF file is related to Creo Parametric 2.0. I do not know how to get document related to Creo Elements/Pro 5.0.
Hi
But in second line it has given J-Link creo parametric 1, J-Link Creo Elements/Pro, Jlink Wildfire 4.0, Wildfire 3.0, Wildfire 2.0. It is applicable to those mentioned creo version also or it will be different.
Please go through the attached snap of the PDF.
@Gopichand wrote:
Hi
these blue text strings represent links to other documents.
