ListComponentsByAssemblyRule and wfcAssemblyExpressionRule return empty result.
Piotr
8-Gravel
Hi All!
My creo is creo Parametric 10.0.3.
How does the wfcAssemblyExpressionRule works ? Can not find any details. Situation goes like:
There is a part with given parameter like YEAR with value 2012.
Part is child of "activeAssembly"
After calling ListComponentsByAssemblyRule with expression  "YEAR==2012" I got something in message window like :
WARNING: Symbol '�䋐ȃ' not found in model XXXXXXXX. Retrieving submodels.
where '�䋐ȃ' is totally random and varies form run to another.  LogTrace  shows that everything is ok with expression string and model. String is std::string passed by copy to local function.  Result is always empty.
Here are lines of code
xstringsequence_ptr stringSeq = xstringsequence::create();
    stringSeq->append(expression.c_str());
    const auto rule = wfcAssemblyExpressionRule::Create(stringSeq);
    wfcAssemblyRule_ptr targetRule = wfcAssemblyRule::cast(rule);
LogTrace(fmt::format("Searching for components with this rule {} in assembly: '{}' ", (string)stringSeq->get(0), (string)activeAssembly->GetInstanceName()));
   LogTrace(fmt::format("wfcAssemblyRuleType {}", (int)targetRule->GetRuleType()));
    const auto components = activeAssembly->ListComponentsByAssemblyRule(targetRule);
ListComponentsByAssemblyRule works for me with  wfcAssemblyNameRule without problems.
What am I doing wrong? Thanks in advance!
Piotr
8-Gravel
(To:Piotr)
I found  Article - CS242290 - ProRuleInitExpr() and ProRuleEval() cannot gather components by parameters. (ptc.com) which is directly connected with my issue. Can you, THE PTC mark such API with attribute like C++ attribute: deprecated (since C++14) - cppreference.com or just delete it?  Does it make any sense to keep this in  API? This does noting and hang there only as a trap which takes time to investigate why again something is wrong,
olivierlp
Community Manager
(To:Piotr)
Hi @Piotr
Thank you for bringing this up. Let us look into it.
Olivier
Thanks for response 🙂 I had bad day(s) with that and searching for walkaround took my time. Hope you will be able to find / do something with that.
RPN
(To:Piotr)
Same here as for finding skeletons, write a visit filter for feature IDs
  • Is the feature ID a component
  • has the parameter you are looking for
  • the parameter is from the type you need
  • the value is matching
If you want, you can do this recursive if the component is an assembly.
