Need Help with VB API Connection
Askarke
I was trying to create a basic code in Vb which allows me to connect to Creo Parametric. I followed the first steps so, I added PRO_COMM_MSG_EXE to System variables, I ran as administrator vb_api_register.bat and I added Creo Parametric VB API Type Library for Creo Parametric to my VB.NET project.
When I try to compile my code, ToolkitCantModify execption appears. Here is my code so I would appreciate if someone could check it because I don´t know if I did something wrong.
Many thanks!
Askarke
(To:Askarke)
could anyone resolve my issue?
I have been searching some info during these days, but i haven't found anything clear.  I tried to set up VB Api configuration again but it didnt work.
Thanks in advance.
TomU
(To:Askarke)
@Askarke,
You're much more likely to get help with VB API on the Creo Parametric Customization board.  You can also find a lot of good information by searching that board for 'VB API'.
Hi Askarke,
I have moved your post to the Creo Parametric Customization board.
Anurag
