We would like to find out thickness of part (which are having cylindrical section) using Toolkit.
Appreciate any help on this.
Regards
Ketan Lalcheta
Thickness mostly makes sense for sheet metal parts. There is a way to inquire the thickness for sheet metal parts.
Thank you for your concern on this.
We would like to know Part thickness for welding decision.
Regards
Ketan
can't you use the measure command 'distance of face to face' or 'distance of surface to surface'.
located in the utilities group in the ribbon
