I am trying to convert my drawing into pdf format however the line thickness of the pdf version is very thick. How can I reduce/change thickness?
Thanks in advance.
It is just a plain text file, you can cut what I have above and paste it into a wordpad or notepad file and name the file table.pnt.
The location can be in your home folder or the start up folder for creo. Be sure to edit the config.pro file so pen_table_file points to your file.
This is where mine points to, it is a network shared drive: pen_table_file X:\PTC_Settings\Plotters\table.pnt
Try these settings in your table.pnt file.
Thanks for your reply. However can you kindly tell me how to create the table.pnt file and where to save it please?
Don't forget to tell the Creo to use the pen table when creating PDFs. See these config options:
Thanks for your reply. However can you kindly tell me how to create the table.pnt file and where to save it please? I have managed to get the configuration menu.
Thanks a lot, it has finally worked!!
You can actually name it whatever you want and store it wherever you want, you just have to set the config option to point to it.
Thank you so much! I have finally managed to get the line thickness as I wish!
