Pfc::XtoolkitCantModify error while trying to connect to creo in other systems.
HanSolo97
The connection string
 Async = CAsync.Connect(Nothing, Nothing, Nothing, 15)
works fine on my system
But the same connection string throws TOOLKITCANTMODIFY error on other systems when running the built exe file. Why is this happening?
syalagudri
(To:HanSolo97)
Try running vb_api_register.bat with admin rights in a machine where you want to execute this program. this enables VB API in that system. This file exist in parametric\bin directory.
remy
(To:HanSolo97)
Some previous case reports that this error message happened due to some typo in some env var.
Given that the issue happens in a different workstation than yours, it seems like a probable cause.
